Thread Tools Rating: Thread Rating: 17 votes, 5.00 average. Display Modes
NickRummy
NickRummy's Avatar
10.12.2009, 10:19 AM
While waiting on the two speed to get here I started looking into something else I've always wanted to do with an RC. It's been done before so it's nothing amazing but I wanted to approach it differently.
This is just too cool right?
Stopped at the local Harbor Freight and found some inner tubes that fit inside the Jumbo Kongs. 8" OD x 2.5"w wide for a 4" rim. I'm running 3.2" rims but that's ok.
Deflated inner tube
Added a little air to see how the fit would be
Not to bad. A little narrow.
Drilled a through hole for the valve stem
Put the tire on.
Added about 10psi to see what would happen.
Since the tube was too narrow it didn't stay centered.
I took the stock foam which is 4" wide and cut 2" out of the center. Then I used the 1" rings left over on either side of the inner tube inside the tire.
NickRummy
NickRummy's Avatar
10.12.2009, 10:21 AM
Inflated to 20psi (on mistake, thought the gauge said 10psi) next to a jumbo kong that has nothing inside it.
You're probable wondering the size difference? The stock Kong measured 8.4". The inflated Kong?
Yes, it's insanely big!
However, 20psi was too much and the inner tube blew sometime over night. I have to pick up another one at lunch today. I built the 3 other tires and they have all held at 10psi so far and measure around 9" OD
Kcaz25
Kcaz25's Avatar
10.12.2009, 10:24 AM
That is so awesome! Big fan of the build! I hope you find a way to make the pneumatics work!
brushlessboy16
brushlessboy16's Avatar
10.12.2009, 10:26 AM
you should be able to float your truck over mud now!
SICK!
very nice addition
NickRummy
NickRummy's Avatar
10.12.2009, 10:33 AM
Thanks guys! Nice thing about the inner tubes is I don't have to worry about gluing in the valve stems or the tires. That was something I didn't want to do. Plus I can easily let the air all the way out for driving around on land and still have some of the foam inside for damping. They had a larger 10" inner tube that I think would fit better but it has a straight valve stem which I'm not sure will fit inside the rim. I'm going to pick one up just to try though.
redshift
RC-Monster Square Tube
redshift's Avatar
10.12.2009, 10:44 PM
Now you just need some belting.... duct tape!
If it works for high speed ballooning it should work for no speed ballooning right?
I wonder if it would just make the tires wider though... just a thought.
Good stuff!
NickRummy
NickRummy's Avatar
10.13.2009, 08:50 AM
Ya know, my friend mentioned the same thing on the phone the other day. I think the only reason the inner tube popped was because the inner tube had expanded so much. With some duct tape limiting how much it can expand that might help fill the tire up with the inner tube instead of it stretching the tire out.....
One thing that I've been finding out I don't like is that the inside of the tire isn't sealed perfectly. I haven't sealed where the valve stem goes in the rim so water can get inside. Obviously only so much water will get in there since the inner tube will still hold air but I'm wondering how much of a buoyancy difference that'll make.
I'm ordering in a different set of wheels that are wider so if this setup doesn't work I'm going to glue a set of tires to the rims and glue in a valve stem too.
Dafni
Dafni's Avatar
10.13.2009, 09:04 AM
yep, I think sealing the tire would be a good idea. Not just because of the loss of buoyancy when the foams get soaked, but also because of the weight and inbalance this water would add to your tires.
NickRummy
NickRummy's Avatar
10.13.2009, 09:24 AM
We're going to see how it does today at lunch time. Brought the truck, a video camera, the tire pump and a good length of rope. If I keep it in water under about 12" deep I don't have to worry about electronics getting wet so if it sinks in about a foot of water I know I failed and it should still drive out without using the rope
NickRummy
NickRummy's Avatar
10.13.2009, 02:00 PM
i just had to run over some stuff with the tires inflated to 10spi
Now for the fun
Video: Chevy Monster in the water
Definitely in need of larger tires with more displacement. It sits way to low under the water.
Kcaz25
Kcaz25's Avatar
10.13.2009, 08:47 PM
That must be one heavy rig! I've seen a Maxx float with uninflaited jumbos
NickRummy
NickRummy's Avatar
10.13.2009, 10:50 PM
It's easily twice the weight of a maxx
That truck just amazes me everytime I see it run. I've gone through all your videos on Youtube. Love it!
How are you keeping the MMM dry?
Thanks! I just have the MMM mounted up high in the chassis to try and keep it out of the water
nitrostarter
nitrostarter's Avatar
10.13.2009, 09:10 PM
N. Rustler conversion
Kcaz25
Kcaz25's Avatar
10.14.2009, 08:21 AM
Cool have you weighted it? What is it? Like 20-25 pounds? I don't see how you are going to get it to float. Maybe attach black(for looks) styrofoam to the axles?
NickRummy
NickRummy's Avatar
10.14.2009, 09:54 AM
It's 20lbs right on the dot. As you seen in the video it was floating with the wheels that are on it right now. They just weren't displacing enough water to keep the truck stable plus they weren't completely sealed so some water started seeping in which is why it started to float lower and lower towards the end of the video.
The set I'm working on now will be complete sealed and have a rim that is 1.5" wider than the rims I used previously. It will float
