10.27.2009, 04:55 PM
Got mine today:
Can't catch this...
10.29.2009, 12:11 PM
Is anyone else having probs with the MMP when useing JR servos??
I have a 650m that causes the esc to flash lights, the light on the RX blinks, and the servo twitches to the right...
BTW the servo works fine on my RX8, and MM
10.29.2009, 12:13 PM
what type of rx are you using?
Can't catch this...
10.29.2009, 12:45 PM
spek 3000
10.29.2009, 01:23 PM
So the JR 650M never operates correctly, the receiver doesn't bind with the TX, and all 3 LED's flash on the Pro? If this is the case, it sounds like the power coming from the Pro's BEC isn't operating correctly.
Does the problem occur when using a different servo?? If it does, then it's a problem with the Pro. If it only does it with that servo, it's a little more puzzling, especially since that servo works on other setups.
Let me know if you get any different results.
Thomas Porfert
Castle Tech Support
10.29.2009, 01:30 PM
Thomas, what does the MMPro do if the servo is pulling too much current?
Also, the servo may be very sensitive to noise from the switching of the BEC, so may try adding a cap to an unused receiver port.
Can't catch this...
10.29.2009, 01:57 PM
tryed that, and it works, BUT it works fine with my RX8 that has a switching BEC...
10.30.2009, 06:58 AM
Got an MMPro4600kv combo coming in the mail, i have a few questions though. Also i have read both this & the other MMPro tech thread.
Do all MMPro's including combo's (with CMS motor) come with the coupon to receive a castle link adapter chip?
The CMS motor that is advertised with the MMPro on the castle website, is it the rebuildable version? I mean is it much easier to get inside the motor with these new CMS series, to ei. change bearings, check rotor, etc...
11.04.2009, 11:27 PM
So i had to find these questions out for myself. Got the coupon for free castle link adapter, & Im quite impressed with the new design of the CMS36 motors.
11.04.2009, 11:40 PM
wow 100k rpm... whats the efficiency like compared to the older style
11.05.2009, 12:36 AM
Shit those look great! I hope they run cooler than the older ones...
2 KiloWatt RACER
11.05.2009, 12:59 AM
Hmmm, I have to get me one. Hopefully the shaft doesn't snap off like its predecessor.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
11.05.2009, 01:03 AM
It would be really great if 5mm on the shaft was an option.
These do look much better built.
11.05.2009, 01:36 AM
2 or 4 pole internals? I am guessing 2 poles, but would be very happy with 4!!! Given the kv is the same (although the 4600 can handle 4s now with the higher rpm limit) I am guessing the internals are updated version of the old 2 pole.
11.05.2009, 01:39 AM
the old 4600 motor said 3s lipo max and these say 4s..... the traxxas noobs are gonna burn those babies up quick!
and i agree i really like the style of the new motors....
