nitrostarter
nitrostarter's Avatar
06.03.2010, 04:03 PM
Romano- what battery box are you using?
I'm looking at the steering servo right now. I have a ACE 1015 which is both strong and fast and will be plenty in a GTP. Most people end up dialing out dual rate and EPA for high speed running. Is this steering servo really necessary? or should I look into a different one?
N. Rustler conversion
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
06.03.2010, 04:25 PM
Thanks again for the pics Snell, the offset is nothing that can't be worked with I dont think. Your efforts are appreciated Sir !
NitroSniffer, I think anything is going to be overkill for straight line duty. I have a NIP JR-650 I'm gonna throw in mine, decent strenth and reliability is my bigger concerns than speed.
nitrostarter
06.03.2010, 04:31 PM
I hear ya Bondoballz. That pretty much what I was thinking. Just thought I would get a few opinions on the subject.
snellemin
2 KiloWatt RACER
snellemin's Avatar
06.03.2010, 04:29 PM
My buddy uses a fast servo, but I just use a plain 'ol slow digital metal gear one. I forgot what model number. I can check later.
Nitro,
that is not a battery box...it's one of those plastic tool drawer things. Tall and wide enough for my cube A123's.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
nitrostarter
06.04.2010, 10:09 AM
Whats the word on ride height? I know the downforce will compress the suspension a bit, but how much? Is this able to be calculated?
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
06.04.2010, 10:28 AM
Great insight and question, I never would have thunk it.
Curious to hear an answer on this myself ?
nitrostarter
06.04.2010, 10:33 AM
I remember watching Indy Car races on tv one day and they showed an explanation video of the amount of suspension travel loss as the cars reach full speed. It was accompanied my an actual video mounted on an indy car to show this in real time. Quite surprising how much it pushes down on the car.
I understand you want to set up the car low, but how low? Too low and a good body would cause the suspension to bottom out going down the straight?
Overdriven
Destroyer of Tires
Overdriven's Avatar
06.04.2010, 11:37 AM
I remember watching Indy Car races on tv one day and they showed an explanation video of the amount of suspension travel loss as the cars reach full speed. It was accompanied by an actual video mounted on an indy car to show this in real time.
You could do the same thing with one of those mini-cams. I probably wasn't thinking about it because I like most guys don't have one. But it could watch the suspension arms while under the body easy enough. If you want to get scientific, place a ruler (or something else with graduations on it for reference) by the arm you're filming to get a more accurate reading of it's position.
Overdriven
Destroyer of Tires
Overdriven's Avatar
06.04.2010, 10:46 AM
Funny thing about Indy + F1 cars, if you need more traction in a corner, go faster. While more speed = more downforce is easily understood, try telling your brain to press on the gas more in that situation!
I'm sure there are formulas Indy + F1 teams use, but they know how much downforce the car makes, spring rates, etc. Doubt anyone knows exactly how much a particular rc body makes. I'm sure someone will pipe in with a useful setup though.
I wonder if you could use something attached to the chassis to see how much the suspension compresses during a run. My first thought is clay, that would wear if it touched pavement, but I'm sure someone could come up with something better.
nitrostarter
06.04.2010, 11:25 AM
Thats actually a good idea.
I was thinking along the line. Something attached to the chassis that would monitor the suspension arms movements. However, the condition of the ground would impair this measurement as the suspension moves on every dip and raise.
I setup my chassis so that it levels out evenly under acceleration. I prefer my driveline to be parallel with the ground as well. But this is just how I run. Setup might need adjustment once I use a different body.
I guess my question is how do you tell chassis position under acceleration beside eyeballing it?
snellemin
2 KiloWatt RACER
snellemin's Avatar
06.04.2010, 11:05 AM
snellemin
2 KiloWatt RACER
snellemin's Avatar
06.04.2010, 11:56 AM
I'm old school and I use eyeballs for my setups. Too much calculating takes away from play time. I use trial and error and have fun doing it. I setup for lets say 60mph and see how the car behaves. I change gearing for a higher speed and see how the car behaves. Calculations will only bring you so far. The only calculations I do, is with the use my simple spreadsheet. And back those numbers up with my datalogger. Kinda works like BrianG calculator. You don't have a wind tunnel to play with, so why waste time calculating things you don't have hard numbers for.
70mph in a 1/8 is pretty damn fast and still affordable to me. 100mph is just stupid fast and I can't afford the upkeep of such a monster without my wife killing me.
nitrostarter
06.04.2010, 12:36 PM
100mph is just cool! Over 100mph is, well its
I want to go 112.15mph which is .01 over my LHS guy's GTP.
snellemin
2 KiloWatt RACER
snellemin's Avatar
06.04.2010, 01:03 PM
Closest I've been, must of been in the lower 90's. Too bad I erased the datalog file by accident of that one and only run. I probably could go faster with better batteries and tires. Probably also getting rid of all the dogbones would help as well. OR or or is it maybe the limitation of my RX8 over the MMM esc.
This is as far as I go when it comes to calculations. Snippet of my spreadsheet. I have one of those for every motor that I have. Vehicle weight is off in this spreadsheet.
PBO
RC-Unobtainium
PBO's Avatar
06.04.2010, 05:56 PM
I'll have a crack at a few considerations;
- in my experience the servo can be anything because steering weight isn't an issue for straight line running. If however you install a gyro, speed becomes an issue...it needs to keep up with gyro. I have a couple of those 1015's - fast, strong & they work nicely with a gyro the way I've used them
- again in my experience fore and aft downforce/suspension can be measured by feel & eyeball. Too soft in the rear & you loose steering when you're accelerating hard...too soft in the front & you'll loose the back end when braking (the back will try & overtake the front). Kind of basic as a theory but it's worked for me
- ride height depends on the running surface. A 1/10 TC has < 1/4" at speed but hit a bump in the road & it's airborne...I would think somewhere between 1/2-3/4" for 1/8 scale is a reasonable starting point. Here's my Rustler...has about 1/2" in the static position. I limited the shock upstroke with fuel tube (pink) so that it never bottomed out but there's no evidence that the shock ever compressed that far...I had it up over 95mph by my GPS
- I would use the stiffest springs available & 50-70wt shock oil, depending on the brand (I use 70wt Losi in my 8T) & then fine tune ride height etc on the shock itself
I look at speed runs as an equation. If the equation is balanced then controllable speed will come relatively easily
Enhanced Rustler 1515 1.5 MMM
Losi 8ight-T
