Thread Tools Rating: Thread Rating: 47 votes, 5.00 average. Display Modes
Good stuff.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Good stuff. - 08.28.2010, 01:53 AM
Nice clean video, and that vehicle seems to have more power then it can handle on 2wd. Very stable platform, and I like how it sits up just a bit giving you great clearance. Very solid looking truck. Now all it needs is a body to match the setup. Thanks for sharing.
SUPERMAXX YOUR LIFE.
mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
08.28.2010, 09:20 AM
I went back and looked to see if you mentioned how long is the wheelbase. I noticed 14.4'', is that right? That's from axle to axle correct? It might be because of the ''thin'' chassis but from the pics and video, the truck looks bigger Cool video by the way, this truck performs extremely well. Tons of ground clearance with a very low CG. It's a total success. Now we have to bombard you with body choices to dress up your ride.
No brain, no headaches.
redshift
RC-Monster Square Tube
redshift's Avatar
A bit confused at the 2wd comment? lol
I assure you it's 4wd, I guess the front wheels aren't doing much in this clip tho.
video
JERRY2KONE
JERRY2KONE's Avatar
video - 08.28.2010, 11:07 AM
Thats funny, because watching the video I did not see the front wheels turning once. No front wheel spin at all.
redshift
redshift's Avatar
08.28.2010, 09:29 AM
Yes 14.4 is correct. I made a comment "wow that's f-ing loose" referring to the surface, and was pretty amazed it was still lifting the front! Still getting used to throttle management on various surfaces, so if it looks like sloppy driving... it is lol.
Thanks MC, I'm more than happy with the results :)
mistercrash
Guelph, Canada, eh!
08.28.2010, 10:56 AM
Here's a suggestion for a body. The Proline F650. I got two of those last year because they were the longest 1/8 MT bodies I could find. It's almost 20'' long and from the middle of the fenders is 14''.
Here's a pic of the two bodies taken before we started using them. After a year of hard bashing, they need to be replaced. They don't look like that anymore
If the hump of your truck requires a taller body then maybe the HPI Bounty Hunter.
redshift
redshift's Avatar
08.29.2010, 03:20 PM
Both nice looking bodies there 'crash, but I'm looking for something WAY tougher. If you ever read my Maxx thread you know I detest body clips, loathe is probably closer actually lol. After going this far it would almost be cheating (for me anyway) to throw a name-brand shell on it. It wouldn't last 5 minutes and I'd be annoyed about time wasted making body posts...
I haven't posted much in the last few days because I've been out giving it some very thorough torture tests. Happy to report the only issue after 3 days of abuse is a blown lower piston e-clip on the front right shock. What do I say about CLIPS? So the shock is full of silicone but the piston is not doing anything. Easy fix and otherwise I feel like the beast was worth every minute spent :)
Got some good video on the way from like 6 different locations, so I'm working on that at the moment. And even some proof for Jerry that it's 4wd
mistercrash
Guelph, Canada, eh!
08.29.2010, 03:33 PM
I don't know what you planned to secure a body to your wonderful creation, but how about some Nylon wing bolts instead of body clips. They can easily be cut to the length you need.
mistercrash
Guelph, Canada, eh!
08.29.2010, 03:50 PM
I told you I would bombard you with body choices
You will need to make your own vaccuform machine and create the Tonka F350 concept truck.
redshift
redshift's Avatar
08.29.2010, 03:44 PM
I'm almost 100% intent on making the packs bottom loading, and the "body" will be semi-permanently attached with screws. Simple idea, but complicated in execution only because I am not sure what I want it to look like still. It might not end up looking like anything, and I'm ok with that too. As long as it ends up looking better than it does nekkid...
I only got the red X for your link, but I know what you're referring to
thzero
08.29.2010, 05:48 PM
What about magnets glued to the shell?
Why not
JERRY2KONE
JERRY2KONE's Avatar
Why not - 08.29.2010, 06:14 PM
Why not set your vehicle up for velcro to hold your body on. Velcro is a great way to hold just about anything together if it is used in the right form. That would also give you a reason to incorperate some kind of roll bars or a roll cage for your vehicles protection.
redshift
redshift's Avatar
08.29.2010, 04:14 PM
I can't decide if I like that or not ^
It's big, that's for sure!
Semi Pro
Semi Pro's Avatar
08.29.2010, 06:22 PM
what a great build, i can't belive i have over looked it, redshift you have got some real skills good luck with the body
redshift
redshift's Avatar
08.29.2010, 07:00 PM
Thanks Semi.
Not sure you're following my logic guys. With the batteries accessible from the bottom side there's no need for the body to be quickly removable.
Maybe 'exoskeleton' is a better word for what I want. The chassis itself needs no further bracing, or a cage, I'm only after component protection, and something to give it more shape. I have plenty of 1/8" lexan and can do it in sections, bent or flat.
I appreciate the suggestions nonetheless :)
