LiqrSicc
LiqrSicc's Avatar
12.05.2010, 12:26 PM
Originally Posted by _dV View Post
Nice, offset looks good on it.
What were the exact dimensions of those spacers? 3/16" spacers (3.57mm) wide and 8mm inside diameter? outside diameter?
Thanks! They're 9/64" wide which comes up to about 3.56mm. 8mm inner diameter and about 12.7mm outer I think.
XXL 1717
SCTE 1512
XXX-S VTA
DX3R
  Send a message via AIM to LiqrSicc
LiqrSicc
LiqrSicc's Avatar
12.05.2010, 12:34 PM
Originally Posted by flowrider View Post
Well, I just received them on Friday. These things are quite heavy which is promising in terms of stability! Now I'm waiting for the rest of my Savage to show up, especially on the Cen Diffs, the 2x CC1520 (Got a CC1717 already but could not resist the black friday sale :) ), Trenchers and my DB XL Tvps.
Yes, I know I need this spacers. Already wrote the guys at the website you posted concerning a quote for max. 10 spacers + shipping. I just don't need 25 pieces which is the smallest quantity they offer. But if you have some spacers lying around which you don't need that would be awesome & I get my PayPal ready!
btw Your truck looks fantastic, but I didn't expect anyrhing else from you!
That setup is gonna be nice! So far my BP diffs are holding up. I have the 1717 too but the 1520 works out so good I don't have the need to use the 1717. I couldnt resist the sales either!
I thought you could buy the spacers individually? Well PM me your address and I can ship you out a set since I have a bunch of extras. I figured I'd get the 25pc order in case there would be a few people who tried the 5t axles as well.
XXL 1717
SCTE 1512
XXX-S VTA
DX3R
thzero
12.05.2010, 01:02 PM
Why'd you go with the 5T axles instead of just using the XL axles? Seems like the latter might have been a cheaper option. Then again, the XL axles a prone to break where the threads begin; was that the issue?
LiqrSicc
LiqrSicc's Avatar
12.05.2010, 03:39 PM
The whole idea was to get away from the threaded axles and to use axles that actually used fit a buggy/truggy 17mm adapters. Not to mention the XL drive cups use the smaller dog bones compared to the Flux
XXL 1717
SCTE 1512
XXX-S VTA
DX3R
thzero
12.05.2010, 04:13 PM
Well, that would be incorrect. The XL and Flux both use the same drive cups and suspension dogbones. The XL axles are just longer by about .5" inches. :)
LiqrSicc
LiqrSicc's Avatar
12.05.2010, 04:26 PM
Yeah you're right. Either way it still has the threaded ends which I really did not want. The only solutions were the 5T axles or the Integy adapters. Both of which I have... the 5T axles just feel a lot beefier than the Integy adapters on the stock axles.
XXL 1717
SCTE 1512
XXX-S VTA
DX3R
toplakd
12.05.2010, 04:28 PM
I have also one XL set of diffs with cups and the flux dogbones do not fit as they are bigger.
Dejan
I removed my signature.
thzero
12.05.2010, 04:38 PM
Im sorry but you are wrong, they do fit. The XL and Flux drive cups are 11mm for the 11mm balls on the dogbones.
Flux Dogbone part #: 86246
XL Dogbone part #: 86246
Flux Drive Cup part #: 86248
XL Drive Cup part #: 86248
Flux Axle: 86928
XL Axle: 86249
I've got two XLs and one Flux. Just saying. And LiqrSicc you should check out my 5T conversion for what i did with the XL axles and the Baja 5B hexes; granted they wont work for your application, but you could do something similiar with the ofna hex adapters if you cant source 5T axles.
Dejan
toplakd
12.05.2010, 04:40 PM
Hi.
I mean those from diff to the wheel side. Center ones are perfect fit. :)
Dejan
thzero
12.05.2010, 06:08 PM
Dejan, sorry but you are not correct. What I listed were the diff cups for the XL and Flux that connect via the SHD (11mm ball) dogones to the XL and Flux axles. The cups that connect the tranny/gearbox to the rear/front dogones are the standard 8mm cups.
Please refer to the manuals:
XL: http://www.hpiracing.com/kitinfo/104246/
Flux: http://www.hpiracing.com/kitinfo/104240/
Or the European versions, which don't differ:
XL: http://www.hpieurope.com/kit-info.ph...&partNo=104248
Flux: http://www.hpieurope.com/kit-info.ph...&partNo=104242
Like I said I have three of these guys; one XL nitro, one XL convert to 5T conversion (see my other thread), and then a Flux (or will be once I decide on the whether to run a standard TVP/axles or XL length TVP/axles).
Hi.
Dejan
toplakd
12.05.2010, 06:28 PM
My bad, I checked now at my car and they are the same.
I have remembered now the driveshaft was cousing problems.
I bought flux driveshafts and guy send me driveshafts with 9mm inside hole.
Dejan
Gdot
12.07.2010, 11:33 AM
i like the chev body. it looks real nice with the black wheels too
