Jahay
05.04.2011, 06:48 AM
this is such an awesome setup! I love it! As long as you can maintain enough structural rigidity and lose enough weight, this will handle so well for a savage!!!
I wish my current build, utilised a similar setup!
You now have plenty of space to mount things above the lipos! Maybe even a large 12s ESC ;) and have the battery slots large enough to take a 4-5s lipo each ;) And a huge motor in the rear haha
Anyway loving it!
Nixpus
05.09.2011, 06:34 AM
Took the G-Savage for a test run and it handles MUCH better than it did last year!! :)
Since I havent balanced the new wheel/rim bombo I ran the old terra pins... still feels a little like driving an elephant on stilts at high speeds - but much less than last year! Im hoping the Mashers will perform better due to the lower side wall (and taping).
Turning radius is absolutely great (tho I dont really understand why a CD help in this area? This was especially noticeable when I let got of the gas and turned at reasonable speeds the truck would turn on a dime! Sweet :)
Will have to play with CD oil... couldn't make the damn thing wheelie no matter what I did! Need to find the golden optimum between handling and MT behaviour!
Will update with some pictures once wireing is done nicely :)
And I still have to figure out how to secure the bats... strapping tape around the TVP's doesn't look good at all... but it works ;)
scarletboa
scarletboa's Avatar
05.09.2011, 11:02 PM
I have some untaped 40 series masters on my xl length flux and they handle much better than I expected. They handle great for being such large tires. Also, I have mine mounted to some axial beadlock rims.
_dV
05.10.2011, 03:12 AM
For my XL length build with CD:-
100K CD fluid - difficult to wheelie and sustain.
500K fluid - easy to wheelie but can be hard to sustain as front wheels still spin up a bit.
Ofna diff lock fluid - v.close to feel of the stock gearbox. easy to wheelie and sustain.
Nixpus
05.10.2011, 05:34 AM
A quick picture of the fatty's ground clearance with Terra pins. I put 1½cm of fuel tube inside the shocks in order to get horizontal "arms"
Here they are:
Thus I have an "on-road" as well as an "off-road" shock set :)
The truck weights in at 6,5kg (14,33 pounds) with the 1717, terra pins and 2 x 5800mAh Turnigys
ID:	9937   Click image for larger version
thzero
05.10.2011, 11:17 AM
In my RC8Te I run 50K in the CD and on 5S/6S can wheelie pretty much on demand; granted it peters out when the power shifts to the front wheels, but it is sustainable. Not nearly so as the locked Savage. Did want to try the Ofna diff lock fluid on a spare diff though, at least for bashing.
thzero
05.10.2011, 11:19 AM
Looks good Nixpus! I do like how you did the batteries, was thinking of the same thing if I redo my Savage 5T conversion.
Bmr4life
Same truck and I think I'm running 50k also, could be 100k. My wheelie won't fall though and it nearly does a backflip. Probably would if the spoiler didn't get in the way. That's running 5s with an 1800kv geared 18/44. Can't use full throttle until I'm doing 30+ and having to flip the truck back over gets old real quick. I'd like to try something like 30k.
thzero
05.10.2011, 11:29 AM
Yeah I'm running a 1800kv too, but am I'm doing 16/50 on Badlands.
Bmr4life
05.10.2011, 11:38 AM
Cool. I'm running IMEX J-Hawgs. My gearing should be more like yours. I just swelled the heck out of my 5s pack.
Knez
Knez's Avatar
05.10.2011, 12:21 PM
Nice!
With those terra pins it looks almost as it can drive upside down too.
Flux 5B CC 1520
1/16 Rally
My Youtube
Russian:Life and Trust is Lost Only Once!
Jahay
05.11.2011, 05:42 AM
looks awesome!!! But i would really like to see the handling performance increase from the LCG using tyres with a thinner side wall!!!! Great Work!
Nixpus
05.11.2011, 11:36 AM
Your right Knez :) Some day I'll have to do a truck which can drive on both sides!
Just weighted the thing without bats and wheels...
My build: 4180grams
Std flux: 4007grams
The wide skid plate + dog bone guard alone weigh 343grams... whic means I'll tick in under a flux once I've removed some alu
Just balanced my mashers... so I'll know how it performs with low sidewall tires quite soon!
Will see if I can make a vid at some point.
Jahay
05.11.2011, 02:53 PM
hmmm thats reminded me.. maybe i should balance my baja wheels and tyres.... ill look at it tonight and see how bad they are...
Im impressed with your overall weight! NOT BAD AT ALL!!! and with some lightening, you will be on to a winner here with the LCG and stronger centre diff setup!
Keep us posted!
Nixpus
05.12.2011, 04:17 AM
I used taggy wax. Pretty straight forward... but it doesn't look super pro!
Truck with Mashers look better than with Terra pins:
Swapping CD oil later and checking high speed handling :)
ID:	9942   Click image for larger version
ID:	9943   Click image for larger version
