Go Back   RC-Monster Forums > Support Forums > Unlimited Engineering
Sylvester
Sylvester's Avatar
12.18.2005, 01:02 PM
You will need the following to complete the whole tranny ; http://www.rc-monster.com/proddetail...R-AL-WS&cat=47 , http://www.rc-monster.com/proddetail...TRX3991&cat=48 , http://www.rc-monster.com/proddetail...TRX3990&cat=48 , http://www.rc-monster.com/proddetail...TRX3994&cat=48 , http://www.rc-monster.com/proddetail...TRX3993&cat=48 , and http://www.rc-monster.com/proddetail...TRX3985&cat=48 . Thats for the complete tranny, are you going to use the aluminum side cover by flm or stock plastic?
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
squeeforever
squeeforever's Avatar
12.18.2005, 01:13 PM
im pretty sure flm. so he wont need the plastic case.
Sylvester
Sylvester's Avatar
12.18.2005, 01:18 PM
Oh, ok, so hes goin full blown aluminum eh;)
Losi 8ight e
captain harlock
RC-Monster Captain
captain harlock's Avatar
12.18.2005, 03:21 PM
Yup, all aluminum big fat truck.
- FLM HYBRID BULKS $150
- FLM HALF CASE $40
- FLM SHOCK TOWERS $48
- FLM EXT. CHASSIS $90
- FLM TRANS. SKID PLATE. $8
- FLM REAR SKID $14
- FLM FRONT SKID $12
- RC-MONSTER HEAT SINK L $30
- RC-MONSTER IDLERS $25
- STROBE SLIPPER KIT $32
- G-MAXX S.SPEED CONV. $59
- SUPER MAXX C.D SHAFTS $56
- SUPERMAXX S.SAVER KIT $78
- SUPER MAXX 6MM CVDS $124+
- DACE HEX ADAPTERS $50
- EXT. BODY $28
- 8SPYDER DIFFS X2 $136+
- RACERX SUSP.KIT $400+
- TONY'S SCREWS $31
- SUPER SHOCKS $79
- TRAXXAS S.TENSION SPRING $2.50
- TRAXXAS OUT PUT SHAFT $7.50
- TRAXXAS INPUT SHAFT $7
- SLIPPER PRESS PLATES $5
- OUT PUT 31T GEAR $3
- BODY CLIPS $3
- MOTOR MOUNT $8
-TRANNY BEARINGS ( Some one tells me)
- TIRES & RIMS $60
- STEEL PILLOWS $26+
- BODY POSTS ( Some one tells me)
Probably that's as far as I can go. What do you think?
Nice to meet you!
captain harlock
RC-Monster Captain
12.18.2005, 03:23 PM
Oops, I forgot the traxxas gearbox halves. $9.25
Nice to meet you!
squeeforever
12.18.2005, 05:41 PM
you wont need the gearbox halfs since you are going to use the flm half and g-maxx conv. also, with the single speed eliminates 1 of the idlers in the tranny so you will only need 1. a few more things to add to your list:
bumpers (i would go stock)
bulkhead braces (i would use rpm plastic or flm)
strobe sprong kit (not required but recommend and if you use this you wont need the stock tension spring)
p.s. were did you find rims and tires for 60 bucks? with 40 series such as the cheyenne and crime fighters or mashers for instance would be closer to 100 bucks.
captain harlock
RC-Monster Captain
12.18.2005, 05:56 PM
For the wheels and rims, Mike sells a pair of premounted rims/tires for 30 dollars. I dont think that the Hybrids need any braces, since they're already come with braces built with them.
The bumpers, where can I find it?
Nice to meet you!
Papa
Papa's Avatar
NO bulkhead braces needed with the hybrid bulks. If you are using the Gmaxx motor mount the sprong will not fit.
captain harlock
RC-Monster Captain
12.18.2005, 05:58 PM
I will not be using the g-maxx motor mount. About the chassis extension you're using in your lovely truck, does it fit in the FLM chassis?
Nice to meet you!
Papa
Papa's Avatar
12.18.2005, 06:04 PM
No FLM here, so no promises. It should work on any chassis that is built to the maxx standard. An exteded rear center drive shaft is needed.
captain harlock
RC-Monster Captain
12.18.2005, 06:08 PM
So, the S.speed tranny consists of one idler, one output gear,....what else? the bearings. How many of them do I need in the single speed tranny?what size? sorry for asking again, could not understand it the first time.
Nice to meet you!
Papa
Papa's Avatar
12.18.2005, 06:12 PM
Hear is a link to the assembly diagram for the tranny The part numbers are listed in the diagram. I suggest you print it out and keep it in your files.
captain harlock
RC-Monster Captain
12.18.2005, 06:14 PM
any suggestions for the bumpers?
Nice to meet you!
Papa
Papa's Avatar
12.18.2005, 06:18 PM
You really do want us to make all your decisions don't you?:L:
Kinda depends on the look you are going for. My stock maxx has an RPM bumper.
captain harlock
RC-Monster Captain
12.18.2005, 06:29 PM
Sorry for being very dependable, but I did not even own a e-maxx befor so please hang in there a bit, okay.
Nice to meet you!
