Thread Tools Rating: Thread Rating: 4 votes, 4.00 average. Display Modes
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
02.08.2012, 06:39 PM
The lower plate is the lower plate - initial pictures were of a working prototype. What is shipping is the finished product. :)
Erevocanuck
02.08.2012, 10:42 PM
I really hope FLM makes a chassis like this for the e-revo and summit near the same price range.One of the biggest complaints for both e-revo and summit is the size of battery that can be used.
02.08.2012, 11:37 PM
I'd like to see someone do an erevo chassis too- just needs beefing up at the front and rear ends to prevent said ends of the truck from bending during use ( see: KershawDesigns erevo chassis epic fail )- the turnbuckle mod that guys do on the stock chassis works just fine and could be integrated into an aftermarket chassis easily enough ( add a nice little machined mount for the rod end that attaches over the shocktower ).
gumleguf
gumleguf's Avatar
02.15.2012, 09:27 AM
Here it is next to a G4 build I am doing:
K1RC
02.15.2012, 12:45 PM
Damn way to make us jealous Just kidding looks pretty sick
sikeston34m
sikeston34m's Avatar
03.01.2012, 06:46 PM
I think this Chassis might work even better with Mike's Battery Trays.
I was looking through the store and have a question.
Which one would work best?
Just the plain 50mm x 150mm tray looks close to what I want.
I want something that will hold 50mm wide packs that will bolt to the chassis using the existing holes.
If you're still around this thread, Can you make a recommendation Mike?
Thanks
RC-Monster Mike
Site Owner
03.01.2012, 06:49 PM
Ideally I think you would want it with a flat bottom - the 50x150 would have mud guard clearance machined into the bottom unless requested otherwise.
sikeston34m
03.01.2012, 07:16 PM
Is there a flat bottom tray in the list that will work well with this?
03.01.2012, 07:38 PM
Just request it with a flat bottom when you place the order ( attach a note ), since they are made to order pretty much if I'm not mistaken.
sikeston34m
03.02.2012, 08:49 AM
Just an idea.
If you're having thoughts of adding a Emaxx FLM Chassis tray to the list, I will buy and then follow up here with pictures of my build to help promote the product.
RC-Monster Mike
Site Owner
03.02.2012, 04:28 PM
I make them in batches, but it is quite easy to make a tray that I have made previously. Also, I would be happy to make a set of trays specific to the FLM chassis as well - all out of them at the moment, though. If you feel like getting some measurements, I can make the trays to the chassis for you. :)
Popoxx
Sapere aude
Popoxx's Avatar
03.02.2012, 06:54 PM
Mike's trays are awesome
Nice trucks gumleguf
sikeston34m
03.03.2012, 01:31 AM
Looks like FLM left plenty of room for packs
I would like my flat bottom trays to be 160mm x 52mm on the inside.
It looks like the Maximum outside side can be up to 175mm x 58mm and still be completely over the aluminum plate.
It's OK if my trays are a little wider on the outside then 58mm. I'm not too worried about impact on the trays, but I'm not sure if 3mm of side would be rigid enough.
I hope this helps.
Let me know what your thoughts are.
sikeston34m
03.08.2012, 11:38 PM
So when is the next battery tray production run?
sikeston34m
03.18.2012, 10:46 AM
WARNING!
You WILL tear up your slipper if you use the original transmission screws without some sort of spacer!
I learned this the hard way.
Which is NOT included or mentioned BTW
Tags
3905, chassis, emaxx, flm, traxxas
