joeling
joeling's Avatar
09.02.2008, 10:43 AM
Well, I use mine in a non racing situation although it's on a track. I had to do the mod since the thing was DOA & I live far far away from CC. I have received my second V2 form Monster Mike. This one is likely to go into my FLM savage. I will run it stock until the BEC dies then do the mod. However, I still hope that I don't have to do any mods.
For the fan, I chop off the original connector & attached another servo lead & plug it into the receiver to receive power from the UBEC. I think a fan or any extra cooling is more than welcome in my part of the world where ambient temperature is anywhere between 30 to 35 deg C during rc session. I think this applies to TruckBasher in Singapore ya ? I was there last week & will be there again end of the month.
Regards,
Joe Ling
Hyper 9e Medusa 4S, Savage 5S MMM 8XL, Jammin' 4S Neu MMM, X2 Ninja JX, X2 MMM 5S Neu, E REVO Medusa 6S
George16
Supermaxx
George16's Avatar
09.02.2008, 10:58 AM
I just bought another since the replacement for my V1 has not arrived yet. I'm leaning on modding it whenever it arrives. I think CC should just do the mod themselves to include installing a UBEC. I think this is easier and faster than retooling again.
But, instead of running a UBEC, I plan on using a rechargeable rx pack from one of my supermaxxes to prevent burning up my 5955TG steering servo. I might still use the fan by using a Y harness coming off of channel 2 or just plug it into channel 3 of my rx.
Is this possible? Thanks.
Or should I just buy the HV 110?
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
09.02.2008, 11:04 AM
...But, instead of running a UBEC, I plan on using a rechargeable rx pack from one of my supermaxxes to prevent burning up my 5955TG steering servo. I might still use the fan by using a Y harness coming off of channel 2 or just plug it into channel 3 of my rx.
If using a reciever pack, the wiring will be a bit different. Give me a little while to whip up a diagram for that...
And, the HV110 is an awesome controller, but lack of reverse, true brakes, and needing to use the pistix adaptor to use a pistol grip radio makes it less than ideal IMO.
joeling
joeling's Avatar
09.02.2008, 11:00 AM
Wow sorry man, My eyes deceive me. On my monitor the orange wire looks like brown. Sorry about that .
Regards,
Joe Ling
George16
Supermaxx
George16's Avatar
09.02.2008, 11:11 AM
Thanks Brian!!!
I'm hoping to receive the MMM from Tower before this coming weekend so I can do the mod and ran my truck. My nitros are taking up all my time again .
I was definitely eyeing the HV 110. Same goes to the MGM .
Revo with OS .18TZ
09.02.2008, 11:16 AM
Here is the wiring diagram for using an Rx pack instead:
09.02.2008, 11:23 AM
Brian it wouldn't it be easier to just use the battery slot on the rx. This would permantly power the MMM and without some kind of switch just drain the battery...
MetalMan
MetalMan's Avatar
09.02.2008, 11:49 AM
Doing so would achieve the same result .
09.02.2008, 11:40 AM
Yup, that can work too. Just making sure people realize that there is a slight wiring change (mainly the ground connection).
George16
Supermaxx
George16's Avatar
So by using a rx pack, I don't have to cut the red wire from the ESC (looking at the diagram). I will be using the batt port on the rx itself so I don't have to splice into the esc wire.
Thanks. Will see how it works when I get my MMM.
Revo with OS .18TZ
09.02.2008, 12:35 PM
I don't think it's that, but people just want to make SURE to do it right and not blow anything. Modding internal circuits is not something that is done by everyone.
And, I said this somewhere before, but the only reason why I made the wiring the way I did in mine was to reduce the rats nest of wires going everywhere, but it obviously is not the ONLY way to do it.
brushlessboy16
brushlessboy16's Avatar
09.02.2008, 04:26 PM
Just did this mod, everuthing went well- everything work but the esc itself, running though a rx pack when i run power to the rx, the fan just spins and the Led's are recognizing throttle input but the esc wont arm, any ideas?
09.02.2008, 06:41 PM
Responded in your other thread...
BlackedOutREVO
09.02.2008, 07:06 PM
Looks like im going to buy a MMM, and just do the mod!
This looks simple enough to pull off, just take my time. Haha
Thanks guys!
TruckBasher
TruckBasher's Avatar
09.02.2008, 09:51 PM
I was almost certain that it was the switch because I have the same exact scenario on the blinking lights but it seems you might have encountered something else...by the way how did you clean the lead between connectors? Just thought something might got cut off....
Hope you get this fixed soon...
Brian dont feel bad about this. You clearly specified from the start that this is NOT an OFFICIAL mod and that it WILL VOID warranty. we are just lucky to get this mod otherwise we wont resurrect our MMM but then again we all do it at OUR OWN RISK. For the rest that wants to try this at home, make sure you DONT CARE about warranty...
Thanks Brian...
E-Slayer direct drive to diff
