Thread Tools Rating: Thread Rating: 5 votes, 4.20 average. Display Modes
brushlessboy16
brushlessboy16's Avatar
03.05.2009, 08:34 AM
My only problem with that is how will ig get my speed back, it throws all my ratios in the trash
George16
Supermaxx
George16's Avatar
03.05.2009, 08:39 AM
What spur/pinion are you using right now? I'm too lazy to read the rest of the posts.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
mkrusedc
NeuMaxx
mkrusedc's Avatar
03.05.2009, 08:40 AM
Gearing and 5s. My Neu 3906 is crazy fast
George16
Supermaxx
George16's Avatar
03.05.2009, 08:45 AM
Same here. I'm using a 51T spur with a 20T pinion on my gmaxx with 8 spider diff gears.
Revo with OS .18TZ
mkrusedc
NeuMaxx
mkrusedc's Avatar
03.05.2009, 10:43 AM
I just checked (because I am senile and forget) that is the gearing I have also 51/20. With that gearing and 5s I cannot keep untaped tires on my rims. They just rip off. If speed is what you want that setup will not let you down.
brushlessboy16
03.05.2009, 04:16 PM
yanked the maxx apart, found out that the diff was not dead, my rear cvd came loose, and the sound was the setscrew in the cup jumping on the pinion shaft
03.05.2009, 06:41 PM
FYI, with hybrid/ UE diffs you only need to use a pinion 1 tooth larger to get the same ratio as with stock diffs (2-3 teeth smaller on the spur works too).
Tags
brushed, kick ass maxx 2, mmm
