Wow, that was much closer than I thought. Gasser does have quite a bit of power and a big weight advantage. OTOH you have 4wd (tho not sure if that helps much.)
Good pull and good vid
Wonder what it would take to tow him around like a bitch?
I think the weight has a lot to do with it, and the traction of his rear tires.
I was surprised that the baja did so well the first 2 pulls ? I reckon with all the weight on them rear tires was the advantage.
It was good to see you previal in the next 2 pulls, Good Job.
Curious to see the tie breaker !?
