Thread Tools Rating: Thread Rating: 17 votes, 5.00 average. Display Modes
NickRummy
NickRummy's Avatar
03.18.2010, 08:37 AM
Time to sort this axle issue out
03.18.2010, 10:20 AM
Hot bodies truggy diffs? They are spiral cut and the pinion looks like a 10t, but that might just be my eyes...
NickRummy
NickRummy's Avatar
03.18.2010, 10:39 AM
Ofna CRT X2 truggy diff
NickRummy
NickRummy's Avatar
04.02.2010, 04:17 PM
Well I have the 3rd member designed finally. Found the final gears I needed. Still needs some small details done but the majority of the work is finished. Just need to add some retaining clips and add link mounts to the axle housing. Then the search begins to find someone who will machine that 3rd member housing....
Final drive ratio came to 5.11. Everything turned out almost exactly 1/6th scale except that I couldn't get all the mounting studs for the 3rd to the housing and the access panel on top is slightly larger than the 1:1.
This thing will be BEEFY.
The exploded 3rd
kevinlambchops
04.03.2010, 03:03 PM
sweeet.
E-sav
04.07.2010, 10:49 AM
Is it not possible for you to utilise anything off of the XTM X-Crawler? I know it's MOA, but it has some of the beefiest looking alloy axles I've ever seen. Plus as it's a super class it probably isn't far off size wise.
NickRummy
NickRummy's Avatar
04.07.2010, 10:54 AM
I'm sure they would probably take some punishment but I'm just not a fan of the way they look, especially being MOA.
Update
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Update - 12.07.2010, 09:33 PM
Have you managed to do anymore with this setup? I love the inflatable tire/wheel setup, very cool. That was a lot of work just to run on water though. I do love how big it sat up once you applied some air to those already huge tires. Good work.
SUPERMAXX YOUR LIFE.
NickRummy
NickRummy's Avatar
12.08.2010, 09:39 AM
Unfortunately not. The guy who is doing the machining for me has been swamped and his schedule is just now freeing up. He told me he's expecting to get started on it in the next week or two.
