Revracer
Revracer's Avatar
01.12.2008, 12:12 AM
it will go in something else. probly my maxx and it will run on 3s in that probly amazingly. since my maxx is lighter. yeh i was looking i found it for 60 at one site. can probly get it less at my LHS with my discount. plus $25 for the heatsink clamp. so not too much for a great motor.
squeeforever
squeeforever's Avatar
01.12.2008, 01:04 AM
Your not listening to me...I might as well give up...First off, you can get the Feigaos from UNITED HOBBIES for HALF of the normal price...Second, you don't HAVE to run a 3S setup. You can easily sell your Maxamps packs, get a good bit of money, and go buy better, cheaper packs from TrueRC. Third, you will most likely lose runtime with the Tekno kit. Like the runtime there claiming with the Tekno kit. Thats ridiculous with a 8000mah pack. Besides, you should get better runtime in a race than bashing. Don't know about you, but I'm easier on the throttle and definitely more precise in a race then running up and down the street...Fourth, the clutch is really useless. I'm running the direct drive setup and the throttle control is amazing, unlike it will be with a clutch. Its just something else thats not necessary.
Revracer
Revracer's Avatar
01.12.2008, 01:12 AM
no i heard you. but im going to be running a smaller motor. support my LHS because im great friends with the owner. so all my parts come through him. the clutch might be useless to you. but i like the nitro driving feel, just not the maintenance. so i want to have something a little like nitro. here its the clutch. im not selling my 3s because i use it in 2 other trucks already. and i am going to get a good set of packs to make a 4s later on down the road. and tekno was running a neu motor, mamba max esc, and a 18/36 gearing. i am running a lightened revo with close ratio, similar electronics, and a 16-18/40. i thank you again for your help with all this. but some things are personal preferance. and my preferance is a clutch. i like the way they feel and drive. and at my LHS, i can probly get a feigao motor for LESS than united hobbies.
lutach
lutach's Avatar
01.12.2008, 11:15 PM
I was able to fix my MBX5T somewhat to put my ACn22/30/2 in it. The steering still messed up from the crash due to lost signal. The smallest pinion I have is 14T and the spur is 49T. I will use my 2 3S 2200mAh packs in series and my Schulze 18.97. The motors Kv is 1770 and with 22.2v should give me a little over 39000rpm. I did a little test on carpet with my DPR and full throttle only showed bursts of 90A and with the 7XL using 4S 5000mAh lipos and my MGM 16016 in the truck I saw burst of over 150A and this was on asphalt. I will see if tomorrow I can run the truck and I'll post some data here and I might do a little video as well.
lutach
lutach's Avatar
01.13.2008, 04:32 PM
Here is a quick video of the MBX5T truggy w/ the Mega Acn22/30/2 (1770Kv), Schulze 18.97 and 2 3S 2200mAh lipos in series (22.2v). This truck was in a bad crash and some parts were bent. I was able to get them as straight as possible, but the motor mount still is a little bent and the pinion and spur doesn't align properly. Here is the video: http://www.youtube.com/v/EAtcnCTdjAI
Almost forgto to mention that the DPR for some reason didn't record the run. My daughter gets a little excided.
