My CRT.5 conversion
IBJAMMIN
IBJAMMIN's Avatar
Talking My CRT.5 conversion - 04.14.2007, 07:57 PM
Well I see there is a couple of CRT.5 conversion projects going on here this is what I have came up with. I wanted a car to run the Mamba max motors I have and once I saw the CRT.5 I new it would be perfect with 1/8th scale diff gears and suspension design in a 1/12th scale car it should be a great platform for brushless motors. :)
I have a 5700kv Mamba and decided to go with a 3s 4000hv Maxamps lipo pack to keep the weight down looking at the numbers 50-60mph should be posible and the weight is right at 4lbs.
I went with the Kyosho 46t spur to keep the pinions reliable I stole some parts off my full size CRT the rear aluminum diff mount and drive cup and pin for the diff gear along with the front center shaft off my HPI savage. I also moved the center diff over to the right side of the chassis to get the battery closer to the centerline and also allow more room for a 4-5s pack later.:)
Name:	e crt 039.jpg
ID:	2744   Click image for larger version
Name:	e crt 040.jpg
ID:	2745   Click image for larger version
Name:	e crt 032.jpg
