-   -   Bulletproof revo tranny? (https://www.rc-monster.com/forum/showthread.php?t=11668)
lincpimp 04.28.2008 10:24 AM
Originally Posted by loa (Post 167122)
Hello,
(added to this thread instead of starting a new one, as Sammus mentionned it)
I'm doing the "locking in 2nd speed" mod right now and my gears are getting dirty.
Any tricks on how to get those gears cleaned up?
Thanks
Loa
Toothbrush and some sort of cleaner, like simple green? The wash them and blow them off! (the last sentence was related to the gears, not body parts)
loa 04.28.2008 03:16 PM
Hello.
Thanks. I cleaned them (the gears!) with a scott towels and finished the job with compressed air. They looked like new!
Loa
rschoi_75 04.29.2008 12:37 PM
Originally Posted by Trick440 (Post 167105)
For the Diffs, just the cups like these? And this will help prevent the larger 'ring gear' gear from breaking teeth?
Large ring gear...
<a href="http://s146.photobucket.com/albums/r272/Trick440/?action=view&current=ringgear.jpg" target="_blank"><img src="http://i146.photobucket.com/albums/r272/Trick440/ringgear.jpg" border="0" alt="Photobucket"></a>
Diff cup...
<a href="http://s146.photobucket.com/albums/r272/Trick440/?action=view&current=RV-025.jpg" target="_blank"><img src="http://i146.photobucket.com/albums/r272/Trick440/RV-025.jpg" border="0" alt="Photobucket"></a>
Thanks guys.
As Brian mentioned, the cups will help the spider gears last longer. You still need to shim the pinion/ring gears.
On another note, you can use an alloy outer diff case as well, which will prolong the life of your ring/pinion gears:
http://www.rc-monster.com/prodimages...ER,%20REVO.jpg
bustitup 04.29.2008 01:47 PM
I have read that if you take the innards out of the 16.8 volt emaxx diff. the fit right in the revo diff's and are much better
also the emaxx 3905 tranny is much stronger?....easy mod
Trick440 04.29.2008 03:21 PM
Shims, they make shims specifically for the Revo? and is there a particular size i would need?
This is a shim right?
<a href="http://s146.photobucket.com/albums/r272/Trick440/?action=view&current=E-MaxxDiff010-1.jpg" target="_blank"><img src="http://i146.photobucket.com/albums/r272/Trick440/E-MaxxDiff010-1.jpg" border="0" alt="Photobucket"></a>
