ssspconcepts.
The differentials are very similar except they are somehow shorter, meaning the diff cup is not as deep. |
I was wondering what a good size gear to run with a crt .5 electric conversion. I'm gonna be running a 6000mah 3s maxamp lipo on a MM 5700.
i got some different gears to run, but notice that the larger ones are hitting my motor mount screws...has anybody else had this problem and if so what screws did ya move to to fix it?
button head screws for mounting the motor will give you more pinion clearance
cool. yeah it was an 18 tooth pinion that i was trying out. but ill give the button head a try if i move to the higher tooth. right now i have a 17 in there and as soon as i hit the throttle it just pops wheelies. can't wait to get it to the track
I'm using a very stupid setup with my truck. A 1930/5 motor, Mamba Max, 4s FlightPower 2500mah and 13/46 gearing. The power is simply astonishing and the tires did not hold up well enough due to the extra rpm the 1930/5 is giving. ( It's running over 70k rpm with this setup). I did not take it outside to see the real face behind this power, but this is only a shot of what it could do.
| All times are GMT -4. The time now is 03:59 AM. |
