http://www.rc-monster.com/proddetail...per-Kit&cat=40 All you need is a ofna gear with a mod 1 pinion. Should last forever.
http://img.photobucket.com/albums/v4...1/P3220202.jpg |
yea sylvester, i didnt think they did :p
If you use the knuckles you have to use the turnbuckles. http://www.rustyonline.net/assets/images/IMG_0354.jpg |
yea, i like the revo knuckles and how you can turn out the bumpsteer with them.
That is seriously the BEST looking body EVER sorry if this has been answered, idon't wanna read alot on a friday night. but is that an extended gmaxx? and how did you get that body mount in the middle?>
erm, its just a standard Gmaxx chassis, no extension.....it may look that way coz the shell sits way low and gives it that lengthened look. here's what the bodymounts look like...the one in front is bolted from the bottom, there's a stock hole in the middle of the "servoplate" and the rears (not extended bodypost btw..) are at the stock location. http://img.photobucket.com/albums/v4...1/P3260172.jpg the hard part was trimming the nose of the shell to fit/clear the various parts, eg shocktowers, oil resevoirs... even the upper suspension links under full compression. |
http://img.photobucket.com/albums/v4...1/P5200096.jpg
http://img.photobucket.com/albums/v4...1/P5200097.jpg http://img.photobucket.com/albums/v4...1/P5200098.jpg finally got my rpm stuff and decided to go dye them parts a lil' different... yes i do like orange! haha. came out looking better than i had expected! anywez, need some help/advice again guys... since i was messing with suspension arms and stuff, decided to rebuild my shocks... what weight oils do you guys use in your shocks? font and rear?.... which pistons do you use? 1 or 2 hole....or 3?...my integy's come with these options. |
WOW! I really like the orange. Have you thought of dying a RPM bumper to match? Anywho, I'm not to certain on the shocks. The weight of the truck would help though.
haha, the thought did cross my mind but then, RPM dun make white front bumpers....erm..or do they?. wahaha..
weight of my truck??? now thats gonna be a bit of a problem then.... |
A guestamate is all we will need. Now that I check, they don't. I thought they use to though. If I'm not mistaken you can get a chrome one and get the chrome off of it and then dye it since it will be white underneath. You can dye all there parts but one to a darker color. I don't think it gets any darker than black ;)
hmm...iguess i could "borrow" my wife's bathroom scale for a bit....let you know as soon as i get it done.
thanks |
The bathroom scale works. It is not real accurate. The truck being light you may have to weigh you with and with out truck.
I'd use 1 piston for sure, the integy shocks have HUGE piston holes! 60-70Wt would be a good place to start off.
| All times are GMT -4. The time now is 06:12 AM. |
