gyn77
05.31.2007, 08:42 AM
Originally Posted by pullstarter
So running 12 cell 4200mah nimh with MM ESC you think the 9XL would be the best choice? Should I have any over heating problems you think? I want to order pretty soon so I want to make sure I get a good combo.
Thanks
Simon
I run with the same setup with only difference I use 4s lipo cells and I think is best choice for normal voltage setup mamba / feigao.
You will need a fan on MM and I put one on 9XL too, but I don't know how 12 Nimh will work instead of lipo cells.
What discharge current allow Intellect 4200 batteries?
If they allow about 70-80 ampere of discharge, I think you can use without problems.
