gyn77
05.31.2007, 08:42 AM
Originally Posted by pullstarter
So running 12 cell 4200mah nimh with MM ESC you think the 9XL would be the best choice? Should I have any over heating problems you think? I want to order pretty soon so I want to make sure I get a good combo.
Thanks
Simon
I run with the same setup with only difference I use 4s lipo cells and I think is best choice for normal voltage setup mamba / feigao.
You will need a fan on MM and I put one on 9XL too, but I don't know how 12 Nimh will work instead of lipo cells.
What discharge current allow Intellect 4200 batteries?
If they allow about 70-80 ampere of discharge, I think you can use without problems.
pullstarter
Pullstarter
06.01.2007, 03:17 AM
I'm not sure on the discharge rate, I may have to bite the bullet and get lipo but not sure if my charger will work on lipo cells that big. It's a team much more CTX andy moore, I know it will charge lipo but i think the max is 1 amp, what amperage do you charge yours at?
gyn77
06.01.2007, 03:25 AM
Lipo must usually be charged 1c.
It means that If you have lipo 4000 mah you must charge them to 4000 mah.
pullstarter
Pullstarter
06.01.2007, 03:36 AM
Thanks gyn much appreciated :018:
