AAngel
06.08.2007, 10:33 AM
Brian, "wow" wasn't the word that I used. LOL
I'm tired of messing with it. I put the MM back into the truck and will run it until my Neu gets back. Then I'll pull the Quark apart and do the mod.
BTW, I did find the little note in the Quark manual saying that if you need finer low speed control, you should narrow the neutral range, so this is probably why zpb has such fine low speed control and I don't. They do warn that running a narrow neutral range can cause cogging. I'll have to try it.
