Thread: BL Xray M18!!!
lutach
lutach's Avatar
09.25.2007, 03:28 PM
Good luck man, I hope that it works for you. I tried the center spool and grenaded both diffs in two runs. I eventually removed it and tried a MIP ctr ball diff, worked much better that way, and helped keep the wear on the ft and rr diffs down. I tried all of the different pinion gears and none worked as well as the viscous setup.
The ball diffs with the center spool is working great so far. I'm finally having a blast. I just have to do some final adjusting of the ball diffs.
