Originally Posted by lutach
I got the Mini-LST ball diffs, Solid center spool and GPM pinion today and I'm breaking them in. So far they are better then the viscous. The ESC is working great with the Hyperion motor. I will run it some more to see how the diffs behave.
Good luck man, I hope that it works for you. I tried the center spool and grenaded both diffs in two runs. I eventually removed it and tried a MIP ctr ball diff, worked much better that way, and helped keep the wear on the ft and rr diffs down. I tried all of the different pinion gears and none worked as well as the viscous setup.
