If you run a 10T pinion or a 11T pinion, it should be in the range of a decent nitro motor using a 4S lipo.
Originally Posted by rchippie
As most of you know i have a ERT.Im running a 62/13 gear with a 1515-1y & MM. The jammin truggy uses a buggy gear ratio in the diff's, thats why the spur is a 62t. My ? is if i went to a kyosho 46t spur & adjusted the pinion size, would it make any difference in performance or not really ?. Thank's
