Matthew_Armeni
Matthew_Armeni's Avatar
11.03.2007, 12:46 AM
ESC plate
Tranny mount for plate
The elec clutch, you don't have to use an e-clip, a 3mm screw and washer work too
The motor mount, the slot is so you can get to the setscrew
And something cool about the motor mount (If I mounted mine in the low position the motor would have just barely rubbed the rear arm, but that's because I am using the RC-Monster heatsink, the higher position fits fine, and it you run a neu there's no interference, I can't give up the extra cooling for lower cg)
And because I live in San Diego, where Tekno is based, regular mail only takes a day to deliever
  Send a message via AIM to Matthew_Armeni
