Matthew_Armeni
Matthew_Armeni's Avatar
11.03.2007, 12:46 AM
ESC plate
Tranny mount for plate
The elec clutch, you don't have to use an e-clip, a 3mm screw and washer work too
The motor mount, the slot is so you can get to the setscrew
And something cool about the motor mount (If I mounted mine in the low position the motor would have just barely rubbed the rear arm, but that's because I am using the RC-Monster heatsink, the higher position fits fine, and it you run a neu there's no interference, I can't give up the extra cooling for lower cg)
And because I live in San Diego, where Tekno is based, regular mail only takes a day to deliever
  Send a message via AIM to Matthew_Armeni
Matthew_Armeni
11.03.2007, 12:57 AM
And finally, a complete shot, after my spur gear incident
11.03.2007, 02:05 AM
So... How is it? Does it run well, any quirks?
Matthew_Armeni
11.03.2007, 02:50 AM
Yeah ,it runs really well, great actually. The quirks I had were my fault, I was in a rush to assemble it and did not properly shim the clutch, it's fine now, and the slipper was a little tight, fixed that as well. Painting the body now, everything will be ready to race for tomorrow
riceman
RC-Monster Gold
riceman's Avatar
11.03.2007, 01:05 PM
Looks great Matt - You racing Barona today? I was going to try to make it out today for the kick off of their Saturday points series. Too many new projects popping up due to the wind/firestorm. Hope to race with you soon.
