Thread
Making an esc better?
MambaMax Mod 2
11
GriffinRU
MambaMax Mod 2 -
11.18.2007, 02:55 PM
Sanding FET's for better adhesion and flatness
Silv
er epoxy Top side of middle Fet's board
Silver epoxy Bottom side of middle Fet's board
Attach brass heatsink to
top
and
bottom
(Remove LED's)
Solder Header to Top Fet's Board
Solder new Caps to Top Fet's Board
Check alignment of top and middle boards
Apply heatsink grease to bottom Fet's of Top Fet's board
Solder headers and caps, trim caps leads
Attach brains pcb, trim header
Prefinal view
Further steps will follow...
To
suicideneil:
Why using bad motor when you can utilize better one, have you checked my thread about 7XL running on sensored mode, borrowing sensors from HV-Maxx motor?
GriffinRU
Find all posts by GriffinRU
