Fast Lane
01.09.2008, 05:13 PM
I suppose I should update the kit to work with stock arms.
They look like they should work fine with the stock arms with some washers to space them out to 1mm, that is to clear the FLM upper arm. Giving the stock upper is narrower than FLM, there should be no problem.
They work perfect on the FLM tower and arm setup.
The FLM arm measures 43mm to the stock 41mm at the point were the shock will mount.
The only thing necessary for it to work with the stock arms is a metal shock bushing, to take up the space were the old shock used to sit.
Our tower is necessary unless you wanted to drill some holes.
