Originally Posted by jhautz
Thanks for the info Jamie. Just the kind of input I was looking for. I already ordered the towers and LST conversion kit from Mike so I'm just making sure I will be able to install this. I really want to stick with the plastic arms. Its going on my savage X along with the tranny forward converion you just released. (Looking forward to this.)
I just want to clarify to make sure I understand...
So it was designed to work with the FLM Towers and Arms, but you think it will work with the stock arms. I would need to mount this on the outside of the arm rather than in the middle section where the stock shocks mount and put a metal shock bushing in the space where the shock would normally mount?
Is that correct? I'm having kind of a hrad time picturing exactly how this would mount to the arm.
Yes we did design this around our set up. However I did check out the X arm and you can mount the shock to the outside of the arm and include the shock spacer in the stock point to fill up the gap
On all new LST kits will include all necessary spacers to work w/o any problems on stock X arms.
