Originally Posted by lincpimp
That is light battery, you should have a really good handling .5 when you are done.
What motor are you going to use? Will you step down to the feigao 8s or are you going to try a different mfg motor? Any specific kv, or are you looking for a less powerful motor? Just curious!
James im using the 7s -5070kv on i got from you. Do you think it will be okay with the truck tires ?.
