02.11.2008, 08:38 PM
Originally Posted by rchippie View Post
James im using the 7s -5070kv on i got from you. Do you think it will be okay with the truck tires ?.
I really do not see any reason that the 7s would not work. You will have to lower the gearing due to the taller tires to maintain the same speed. I would say to try it and keep checking your temps. The s can motors are pretty good motors, you could step up to a l can, or go to 3s but both will increase weight.
