02.12.2008, 08:33 PM
I wanna do a Traxxas Villian Boat with a pair of these AXI 2826/8 motors, a CC BEC, a pair of MM ESC's, and a 4S 10,000mah Lipo setup. They have enough torque to get it up far into the "fun" zone.
HAHA
That think will fly. I can't see the supervee motor being as powerful as one of those axi motors. You should easily get that boat over 50mph, which will be ridiculous. I hope the boat can keep up with that kind of power. My supervee's hull is completely out of the water at 42mph, I really can't see it going any faster and still stay upright!
Do you have the boat yet? You might be able to get away with the sidewinder esc, it is half the cost of the mm, just not sure if it is 4s capable? You can set the lvc to the same values as the mm so it should be good for 5s! I got mine for 65 bucks from tower, that 130 for two and you may be able to get the axi motors cheap too. So far my sidewinder runs cooler than my MM did in the xxx-cr. Not sure why, maybe the heatsink is on better?
That boat would be wicked!
