03.17.2008, 03:50 PM
Your 80 amps max 4s lipo will be the limiting factor. Gearing over 35mph will most likely overdraw the batteries, regardless of the motor used. The align xl is a decent choice for a motor, however the 16t pinion will not get you much more than 30mph. The motor kv of 1670 is too low for 4s, total rpm will be around 24,000. I would suggest a feiago 9xl, but you do not want a feigao. Any specific reason?
