kevin1
03.17.2008, 03:58 PM
Your 80 amps max 4s lipo will be the limiting factor. Gearing over 35mph will most likely overdraw the batteries, regardless of the motor used. The align xl is a decent choice for a motor, however the 16t pinion will not get you much more than 30mph. The motor kv of 1670 is too low for 4s, total rpm will be around 24,000. I would suggest a feiago 9xl, but you do not want a feigao. Any specific reason?
I had have a lot of problems whith feigao,
I don't know explain this in english, sorry
and OK for the align, it isn't good
what do you think about hacker and lehner motors ? or others
