BashOn
04.02.2008, 06:42 PM
Realy good!! But in which mode do you run your controlller now?? Cut off or reduce RPM??
I'm running Reduce RPM. My truck is down for the moment but I am going to give cutoff a run on my next outing. I am quite sure that it isn't going to cutoff. Just looking at the data on the software I can see that the controller is allowing full throttle output, which it never had before. It will be a week or two before I get a replacement hybrid bulk from FLM though...
