Originally Posted by david lamontagn
Realy good!! But in which mode do you run your controlller now?? Cut off or reduce RPM??
I'm running Reduce RPM. My truck is down for the moment but I am going to give cutoff a run on my next outing. I am quite sure that it isn't going to cutoff. Just looking at the data on the software I can see that the controller is allowing full throttle output, which it never had before. It will be a week or two before I get a replacement hybrid bulk from FLM though...
