xcntrk
xcntrk's Avatar
04.04.2008, 08:05 AM
Thanks for the feedback all!
Nice job! What kind of tires are those?
They’re Axial Terra-izers in 40 series.
Originally Posted by aqwut View Post
Awesome dude.. it's basically an E-Maxx now... how much that thing weigh?..
Looks great man!! Nice job! Did the E-Maxx tranny go right in or were new holes needed to be drilled?
It’s essentially an Emaxx tranny with motor plate installed on the UE Thunder (nitro) extended chassis. The Emaxx tranny mount is the same as the nitro tranny, but it is a taller box and hangs down lower then the original unit (beyond the frame rails). This prevents my center skid from clearing. I’ll probably shim out the skid to make it fit. Also the Emaxx tranny has a shorter output shaft and required a custom length front dogbone. Took me a while to find the right size; I'm presently running a 72mm but 70mm would be ideal.
