orangecrush
04.20.2008, 01:47 PM
Hey what radio are you using with this controller? Maybe there is a communication issue between the two? Like linc says we know it is frustrating but you should keep trying. Maybe one of the guys who have more experience with the MGM can either help to get it set up, or maybe even set it up for you and send it back. Then you will know for sure if something is wrong with the MGM or something else. For the money anything is worth a try, and when it is finally setup and running all of the bad will be lost. If there is one characteristic that matters most in our hobby it is patients. and maybe a good shot of Tiquila once in a while. Good luck with your issues.
Jerry,
I'm using a Spektrum 3.0 radio. It's the same one I've been using. Each time I use a different (same brand, same model, just different controller), I get different problems.
Maybe try it off?
The only option I haven't tried is changing it back to race mode and install the low voltage shut off back in it again.
That's what I've been doing until I received the new controller. Maybe I need to go back to doing that AGAIN...
[QUOTE=kingiggy262;164680]A few guys have reported some similar problems that you have been having in this thread: http://www.rc-monster.com/forum/show...gm+low+voltage
Thanks King, the new controller is 3.22.... new updates, new problems.
Originally Posted by Serum View Post
There is a mess-up in the manual, that freewheel option isn't free-wheel as you might know it.. I had the same weird programming thing with my 24160..
So what are you saying? Use or not use freewheel? I've got it "on" now.
Thanks all...
Mark
