04.23.2008, 02:18 PM
Originally Posted by jzemaxx View Post
They make a high amp model as well of this BEC. But I don't think its needed unless you run alot of digital servos.
However, that one is not rated as high voltage. It would be expensive, but you should be able to parallel two of the HV ones. You won't get exactly double the current, but at least 75% more, so around 6A.
