Originally Posted by GriffinRU
No, this $85 ESC from e-bay with motor and programming card.
The one which you sent me for MCU transplantation is still in progress. And the ones which you are going to send me I haven't seen yet, unless there are from the same family...
I do have that same $85 one, but the brain board on the one I have is different. I think the brain board on yours is the plane one and you can see them both in some previous pictures. I was having the same issues you are having when I only had the plane controller. Now I'm not sure as well. I could give a crack at it and swap the brain boards myself and if it works out, I'll send it to you to see if you can add an extra board from a 50A controller I have (Same as the 100A, but with one power board). The start up procedure in the $85 controller is the same as my Actronic 120 and it's funny as they say it's to ensure maximum throttle and brake.
