lutach
lutach's Avatar
04.26.2008, 04:39 PM
Originally Posted by GriffinRU View Post
I am not happy with that ESC in general...
Is it operational? Yes and kind of no, I do not like how it works.
Luciano what you would like to do with that "cheap" (not really) ESC?
No comparison to MM neither in price, quality or features. I even put BK on top of it not even mentioning schulze.
Anyone would like to have this combo can shoot me PM, I have spare one.
The ones that I sent you? Or the ones that you have that I was going to send you?
GriffinRU
04.26.2008, 04:45 PM
No, this $85 ESC from e-bay with motor and programming card.
The one which you sent me for MCU transplantation is still in progress. And the ones which you are going to send me I haven't seen yet, unless there are from the same family...
lutach
lutach's Avatar
04.26.2008, 05:32 PM
I do have that same $85 one, but the brain board on the one I have is different. I think the brain board on yours is the plane one and you can see them both in some previous pictures. I was having the same issues you are having when I only had the plane controller. Now I'm not sure as well. I could give a crack at it and swap the brain boards myself and if it works out, I'll send it to you to see if you can add an extra board from a 50A controller I have (Same as the 100A, but with one power board). The start up procedure in the $85 controller is the same as my Actronic 120 and it's funny as they say it's to ensure maximum throttle and brake.
05.03.2008, 11:11 AM
http://cgi.ebay.co.uk/100A-ESC-Brush...QQcmdZViewItem
Another contender....
lutach
lutach's Avatar
05.03.2008, 11:23 AM
I contacted the place that makes those. I think you can also check Danlions, they have a car controller as well as those HV100 and HV200 I posted pictures of. I'm still trying to find where they get them from. All those controllers are sold as a kit to them and all they do is add the components they like.
06.01.2008, 09:03 PM
Another contender enters the ring...
http://www.afterbuy.de/afterbuy/shop...duktid=7826389
This one has a cool little programming box as an optional extra. There are also OPTO version with PC programming, but Im not certain they have brakes, just forwards & reverse (odd...). The site is in german, so I did some translating via Babelfish:
Overdrive Racing Brushless automatic controller Rocket XC 100A Rocket XC 100A - for car and airplane The phantom & Rocket XC Brushless series of Overdrive Racing makes the entrance possible into the Brushless world to an unbeatable price performance ratio.
Description of article Rocket XC 100A:
Brushless automatic controller of the top class from the Rocket XC series with overheating & Low-voltage protection.
Driving option: Only forward/forwardbackwards.
Different starting options of gentle starting on loose underground up to the power start with much Gripp.
Different brake functions of more easily ABS brake to hard Vollbremsung up to the stop. Akkuschutz by low-voltage option, in this option can select you of 0,0 - 49.9 V whether the automatic controller switches or the achievement off reduced.
Adjustable middle gas range of 0-29%.
In 3 stages adjustable timing.
PWM frequency: 13KHz and 8KHz.
Adjustable automatic controller speed (constant speed) only in the switchable flying operation.
Attitude gas relationship for forward and backwards.
Type of model: RC car or flight Programmable by remote control or that particularly for it developed electronic program box with LCD display.
(Program box is not contained in the scope of supply) We recommend very easy and fast programming by program box. (You find the program box in our shop) Also for flight models applicably.
Heres the OPTO version, with a screen shot of the programming interface:
http://www.afterbuy.de/afterbuy/shop...duktid=8106755
lutach
lutach's Avatar
06.01.2008, 10:40 PM
I actually contacted the manufacturer of those and they will make a 6S and a 10S for me to try out and see if it'll work with different types of motors. They should be ready soon as I was told it should take at least a month.
06.02.2008, 10:51 AM
Damn it man, are there any esc manufacturers you havent contacted?
I like the programming box and PC programming options alot, and the car software seems pretty sound, just going by the description. Only thing you can never tell is how good/ reliable the hardware is- I guess you will find out soon enough...
lutach
lutach's Avatar
06.02.2008, 10:56 AM
I have to contact any manufacturer that uses electronic components to keep my daughter happy . Here is what you can do for us for the time being . Get this one: http://cgi.ebay.com/100A-ESC-Brushle...QQcmdZViewItem , it will be cheaper then the one you found even though it'll come from Canada. Try it out and let me know how it goes. I will also wait to see what the manufacturer will send me and they seem legit as I asked a few questions and all the answers were good.
06.02.2008, 11:54 AM
Haha, I am half tempted by that esc, especially at that price too, but it is only good for 5s lipo.. kinda would like it to be 6s for certain and then it would be a good choice. I wanna see what the RX8 comes out like, or if Novak hurry up with the 6s sensored models (just need proper big sensored motors, no-one makes them anymore for MTs...).
asheck
06.02.2008, 01:29 PM
.So has anyone on here tested that 1 yet?I've been thinking of trying it,but can't decide.
06.27.2008, 07:19 PM
http://global.ebay.com/gbh/viItem?ItemId=370041594514
Found by a traxxas forum member, would you believe...
GriffinRU
06.27.2008, 07:36 PM
I like the features list, especially line #6
"6. Low-Dropout Regulators used for the IC to provide current for BEC. (1A, 2A, 3A)"
Very important parameter when you dropping from Battery Voltage (5S ~25V) down to BEC Voltage
P.S. How cheap it can get?
Another cool place...
6mm shaft KB46 not 36 motors
timaneli
06.29.2008, 11:41 AM
yes i believe neil!!
was me who found it!!!
let´s see what people around here think of it!!
regards
lutach
lutach's Avatar
06.29.2008, 12:12 PM
You guys know if you to to the website it's even cheaper. I bought a couple controllers from them already, but they were the small airplane ones and I tought they were the one with the car software (I saw the program box and it said for car, but it wasn't). Here is the link: http://www.cnchelicopter.com/servlet...ial-**-/Detail.
