Pdelcast
Pdelcast's Avatar
06.08.2008, 02:45 AM
Originally Posted by GriffinRU View Post
Sure is a lot easier to build a high power controller when you only have a single phase...
Probably just a couple Eupec IGBTs. Pretty simple. -- What isn't talked about is the RADIATOR that that controller requires -- and water pump, and plumbing... 2 watts of loss per amp just for forward drop, minimum.
IGBT drivers can be a challenge in three phase setups, but single phase is a breeze.
Patrick del Castillo
President, Principle Engineer
