pumpkinfish
06.13.2008, 09:07 AM
Originally Posted by TDC57 View Post
I am going to order the referenced sway bars above (thanks for the tip ) and I'm going with one size heavy spring (light blue??) the reason being the bottom kept hitting the ground every time it landed off any size jump. We’ll see..
Thanks for the comments PF and have a great one..
Shaun.
Shaun,
If you are bottoming out try changing the pack of your shocks first. What setup did you use? If you go to RCTech, Rocco a factory Xray driver can give you some great pointers on the 808. Fortunately for me, he posted a starting setup for his local track which matches my local track description.
One thing I can say about the 808 is that is very sensitive to changes. I was practicing last night and played with a few things. Every time I made a change, it was very noticeable on the track the very next lap. I lowered the rear inner camber link to the lowest hole and wow was it a completely different car. I also put a thicker rear diff fluid in and the car was almost undriveable. I think for this car going with anything in the range of 1k-2k is the ticket. I am still playing with the front and center diff fluids. Also, I raised my ride height slightly and it was drastic. I found at my track that a high ride height is not a good a thing. I would set the ride height no higher than arms level and even that might be too high.
-John
