Thread Tools Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
TDC57
TDC57's Avatar
06.13.2008, 12:46 AM
Originally Posted by pumpkinfish View Post
Just saw this thread. Wow you really didn't need all those hop-ups. My 777 needed them. In my experience, the aluminum chassis braces are too stiff unless you are on an indoor clay track. Keep the aluminum towers and ackerman plate as backups. The only hop-ups I put on mine were the carbon fiber center diff plate and carbon fiber front upper brace (steering brace). Oh yea I forgot that I put on the Losi lexan rear arm "mud flaps"...lol!
The one thing I highly recommend to all 808 owners is switching out the sway bars; they are way too stiff in my opinion. I went with 2.2 front and 2.4 rear and it feels awesome now.
Enjoy it as it is a really fun buggy to drive!
What's up Pumpkinfish (like the name!).
Yea I know, I know I don’t need all of those hop-ups parts, like many guys don’t need the blue pill either but they get it!..
As luck would have it the track that I'm running it at is a indoor clay track so see some of that bling will actually help.. . I actually haven’t decided to take apart my perfectly good running / driving buggy “to weigh it down & pretty it up” but if do that get that wild hair up my a$$ them I'm at least prepared for it..
I am going to order the referenced sway bars above (thanks for the tip ) and I'm going with one size heavy spring (light blue??) the reason being the bottom kept hitting the ground every time it landed off any size jump. We’ll see..
Thanks for the comments PF and have a great one..
Shaun.
Nothing!.. Hahahahaaa..
pumpkinfish
06.13.2008, 09:07 AM
Shaun.
Shaun,
If you are bottoming out try changing the pack of your shocks first. What setup did you use? If you go to RCTech, Rocco a factory Xray driver can give you some great pointers on the 808. Fortunately for me, he posted a starting setup for his local track which matches my local track description.
One thing I can say about the 808 is that is very sensitive to changes. I was practicing last night and played with a few things. Every time I made a change, it was very noticeable on the track the very next lap. I lowered the rear inner camber link to the lowest hole and wow was it a completely different car. I also put a thicker rear diff fluid in and the car was almost undriveable. I think for this car going with anything in the range of 1k-2k is the ticket. I am still playing with the front and center diff fluids. Also, I raised my ride height slightly and it was drastic. I found at my track that a high ride height is not a good a thing. I would set the ride height no higher than arms level and even that might be too high.
-John
