lutach
lutach's Avatar
06.20.2008, 11:56 AM
One thing that did occur to me is that using truggy ratio diffs instead of buggy would lower the gearing a fair bit- I'd say plumb the numbers into the calculator and see what it says. In theory, the truggy ring gear & pinion is all you should need to make the change, so you can keep the rest of the UE 8spider diff (a bit of shimming perhaps, but little more)...
You are right. The RC8 for example uses 4.3 diff ratio. I used the HB buggy diffs to do my speed runs and now the truggy diffs are back in for some fun times . My MBX5T had the buggy diffs as well and now it has the truggy diffs for again some fun times . Shimming is a must with the 4.3 truggy ring gear and pinion.
