Originally Posted by BrianG
No, motor wires connected "wrong" will only make the motor spin the wrong way. The only thing that matters is that all three wires are securely connected.
First, set your radio endpoints to 100% for both brake/reverse and fowards, and then set the trim to 0 (centered). Then try again.
Okay I will try that and get back to you. Thanks for the help thus far.
