Originally Posted by Finnster
Correct. i have one. Any controller that says "opto" means there is no BEC. If you want to use the full capabilities of the 9032, you need a BEC capable of ~40V. The UBEC Mike sells is one of the best of a small field of BECs capable of this.
with an OPTO ESC is there a need to pull the red wire from the cable that goes from the ESC to the Rx when using an external BEC
