lutach
lutach's Avatar
07.21.2008, 01:29 PM
In that case, I doubt it will be much better than a feigao. It will disapate heat better, and the can will not come apart as easy. Those are reason enough to buy this over a smooth, pressed endbell feigao.
Yes, the extra material will help the motor with heat issues. The bad thing about the 45mm cans is that they won't fit my MBX5T. I'm afraid to try them in my BPP and the extra weight of the truck will probably be too much for the 1/8" shaft.
