07.21.2008, 01:17 PM
Both the ones I have use one single magnet. It's a good thing to do is to open the motor and clean the magnet as I found some small peices of magnet stuck to the rotor. I might even go a bit crazy when the 2 correct motors comes in and wrap the magnet with either Kevlar, Carbon Fiber or some Spectra. The windings are basically the same as most Feigao and KD type motors.
In that case, I doubt it will be much better than a feigao. It will disapate heat better, and the can will not come apart as easy. Those are reason enough to buy this over a smooth, pressed endbell feigao.
