Different!
ilpufxit
ilpufxit's Avatar
Different! - 07.31.2008, 12:11 PM
I was using one of Holmes Hobbies early custom jobs, It's a large, low kv outrunner directly running the input shaft. It's a neat set up for speed runs but it's not really very good for the application, too much mass to spin from start-up and it's very sensitive to driveline shock. If I did it again, I would use a slipper and an inrunner motor. However, with what I learned between the e-maxx and the LST, I ended up building a BL Muggy which is way better than either one imho. The Muggy is simply much better handling, mostly due to a low cg but I do wish that Mike would make with the Slipperential!!
Originally Posted by lind5 View Post
ok chassis mods not a problem emaxx box alreadt upgraded but did you use std emaxx spur or somthing diffrent
cheers mate
