lind5
07.31.2008, 06:02 AM
ok chassis mods not a problem emaxx box alreadt upgraded but did you use std emaxx spur or somthing diffrent
cheers mate
Originally Posted by ilpufxit View Post
I did this, it works with some mods to the LST chassis, the gearing is ok. The maxx box in stock form won't hold up well if you're running any serious power though.
captanabolic
captanabolic's Avatar
07.31.2008, 11:42 AM
Ok I got the motor mount installed did not have time to run it. Fit and finish were nice bet the production model will be sweet. The dude and I were worried about bracing the larger Neu motor. I can honestly say that I do not believe a brace is necessary. It took quite a bit of force to get the motor and the mount to flex. It fit perfect in the mounting locations and some 4mm button heads to secure it to chassis. It is very rigid. The swivel action is a great feature for setting the gear mesh. So far overall looks like it will be another homerun. I am going to use plastic spurs this weekend so I can tell if the motor mount is flexing causing funny spur wear. Here are some quick pics of it mounted up. gonna have to do some creative work to get the gear cover on. LOL
http://captanabolic.onestop.net/drift_manga.gif
FAST ENOUGH TO DO SOMETHING STUPID
REALLY STUPID
THE CAPT IS SOOO SEXY!!!
HOLY HOLE IN THE DONUT BATMAN!!!
Different!
ilpufxit
ilpufxit's Avatar
Different! - 07.31.2008, 12:11 PM
I was using one of Holmes Hobbies early custom jobs, It's a large, low kv outrunner directly running the input shaft. It's a neat set up for speed runs but it's not really very good for the application, too much mass to spin from start-up and it's very sensitive to driveline shock. If I did it again, I would use a slipper and an inrunner motor. However, with what I learned between the e-maxx and the LST, I ended up building a BL Muggy which is way better than either one imho. The Muggy is simply much better handling, mostly due to a low cg but I do wish that Mike would make with the Slipperential!!
cheers mate
mickeymoose
07.31.2008, 10:54 PM
Here's one I built with an E-Maxx tranny. AS long as you do all the upgrades to the tranny ( upgrade pin on input shaft gear, steel idler gear, and gorilla maxx drive adapter ) it works great. Here's a couple of pics.
http://i68.photobucket.com/albums/i2...splates007.jpg
http://i68.photobucket.com/albums/i2...splates008.jpg
http://i68.photobucket.com/albums/i2...splates005.jpg
http://i68.photobucket.com/albums/i2...splates002.jpg
http://i68.photobucket.com/albums/i2...e_1/truck3.jpg
http://i68.photobucket.com/albums/i2...e_1/truck2.jpg
lind5
08.01.2008, 10:59 AM
hi mate i was gonna try do something with my chassis but what you have there looks ideal any chance on some info on where i can get one like that or did you make it your self
what spur and pinion you running on that
TexasSP
Something, anything, nothing
TexasSP's Avatar
08.01.2008, 11:33 AM
That maxx-tranny job looks factory. Nice job on it for sure.
I think there is an excellent market for someone who comes out with a nice lst/lst2/aftershock electric conversion kit.
www.cubicle101.com
mickeymoose
08.01.2008, 10:06 PM
Hi I made it myself, I'm running mod1 gears 9XL with 18t pinion and 52t spur, I'm using an MGT spur/slipper, it's exactly like an E-Maxx slipper only mod1.
lind5
08.02.2008, 04:42 AM
ok mate well good job done on making it your self look great
thanks for the pm and if you do ever make any more bear me in mind its better than i could ever do
TexasSP
TexasSP's Avatar
08.02.2008, 03:34 PM
If you have the chassis designed on cad you could at least sell the file, I am sure many would pay for it. Or even better, make them yourself and sell them. I think basing it off the 3905 tranny would be best.
Again, it is a very impressive conversion to say the least.
www.cubicle101.com
mickeymoose
08.02.2008, 09:36 PM
Thanks for all the good words guys. The truck does work extremly well though, I personally think it's a better option than a Revo IMHO. I think you guys are convincing me to produce some of these, but make no mistake it is very time consuming pursuing things like this. I looked at the 3905 tranny, but I'm pretty sure it would not work for this application because the motor mount flares out right at the bottom of the tranny and it looked to me like it would interfere with the battery tray mount location. Thanks again for the compliments.
lind5
Arrow 08.03.2008, 07:44 AM
hopefully your get them into production soon
i got my mgt rr slipper and spur turning up soon 54 tooth
i have also been told that the lst 2 speed 2nd gear will fit the rr slipper hub. not sure how it would effect the gearing as this seems to be a fair bit bigger 60+ teeth
how would effect the temps of the motor esc and batterys as i am going to be useing the old emaxx transmision on the lst chassis
pinions i have to use are the 16/17/18/and 20 tooth
lind5
08.04.2008, 11:59 AM
hi got a second hand emax chassis today so im gonna try mount that onto the top deck of the lst that should give me a base to put the emax transmision and some where to mount the lipos
at least i will be able get it together and then see about getting some kind of alloy chassis made made up to replace stock one whilst weighting for my mamba monster 2200 kv combo
Geogenesis13
RC-Monster Ruthenium
Geogenesis13's Avatar
08.05.2008, 01:13 AM
lind5 why aren't you impressed with the revo
"Its a bird."Its a plane.""It is my E-Revo and bl 5T you idiots."
lind5
08.05.2008, 05:11 AM
hi mate well i built it from scratch everything was new i didnt use a donner car
gmaxx chassis
gmaxx single speed
gmaxx single motor mount
emaxx gearbox
complete metal gears
quark monster pro esc (now cooked)
1515 1.5 motor
3 racing alloy diff cups
3 racing alloy bumpers
integy alloy tie bars
integy alloy skid plates
traxxas cvds (snapped x2)
traxxas red alloy tie rods (snapped x2)
traxxas red alloy steering arms (snapped x1)
traxxas hard anodised pivot balls
rpm wishbones
rpm hubs (piviot ball pulled out x2)
titanium hinge pins
proline 23mm wheel hex (inner pins snapped x?)
proline 23mm 40 series wheels
proline 40 series max mulchers
proline single steering arm
i think thats about
well any way it seems every time i took it out some thing broke on it
and when you have spent this much hard ernt cash it just p****s me off
but i can beat the crap out of my lst and it just keeps going so that is why im now wanting to convert this one
TexasSP
TexasSP's Avatar
08.05.2008, 01:14 PM
You had a lot of weight on that revo with all the aluminum. That was probably a lot of your issue with breakage. When that much weight moves around at high speed in a truck that size, carnage gets worse. I went through this with my first to maxxes. Adding aluminum everywhere and trying to make it bullet proof, but the more I put on the more problems I had. My 3905 maxx is basically stock except for the BL system and radio and I don't have hardly any problems. If I break a part I replace it with a stock part and go on.
www.cubicle101.com
